@brown_beret7 avatar
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
The original centre stand on my recently bought 2001 ET4 is quite bashed so I've refurbed and resprayed a second hand one and went to fit it along with new springs. The nut on the centre bolt was pretty rusted up though I managed to free it, but the bolt head on the other end is fast and I can't seem to shift it even with a ring spanner and a fair whack.
I see on the parts diagram that the stand is fitted with just this bolt and a spacer, so just wondering whether to key trying to release the old bolt (keep unscrewing or try to drive it out?) or buy a new bolt and spacer and cut off the original in the centre and drive out either end before fitting the new parts?
Any thoughts or tips would be really welcome?!
Paul
@menhir avatar
@menhir avatar
Moved here from the Wiki.
Spin the nut back on the bolt to get it flush with the end, then whack it with a 2lb lump hammer. This shouldn't harm the end of the bolt, or the threads, but should deffo free the bolt!
Thanks Jim, good tip.
Gave that a try but it's not shifting, but then I've only managed to get the scoot slightly up on some blocks so still I'm flat on my back underneath and can't get a good swing! (the rear brake cable also runs across the line...)
It'd be easier to work on if the scoot was on it's side but I'm a bit reluctant - other than making sure the fuel cap is well screwed on and the side panels have a soft cushion, what else would I need to bear in mind if I decided to tip her to work on the underside and stand more easily? Any issues with the carb or oil flows etc?
Cheers,
Paul
[ Time: 0.0087s ][ Queries: 3 (0.0032s) ][ live ][ 313 ][ ThingOne ]
