1965 SS180, 2008 S 150
This is a European model 1965 Vespa 180SS. The frame number is VSC1T 0013447. I am in San Diego and asking $3200.
Work done since I have owned it:
gear oil, all plugs, all bulbs, air filter, air bellow, shift cables, throttle cables, battery terminals, battery, rubber buffer in battery tray, new center kick stand boots, new kick start lever and shaft, new rear shock absorber, new fly wheel side seals, new hardware on fan and cylinder shroud, replaced wire ignition switch, replace city light wire, new tail light assembly, new wiring sheathing going to stator, new brake switch, new front brake shoes and new regulator for running lights, cowel rubber seals, replaced tail light assembly...
repacked selector box with grease, repaired cable plate in headset, wire ignition switch repaired, pulled rear hub, de coke top end, cleaned brakes, re-torqued hub nut, re-packed fly wheel side main bearing, rewired ignition, split engine cases and reassemble motor, fixed wires at the stator plate junction box, set timing and points gap, cleaned headlamp bulb base, rebuilt brake pedal with new pin, greased fork link, cleaned cup front hub.
All electrical systems are working. Needs speedo and horn cables connected and may need repack front wheel bearings with grease. My intention was to complete a full restoration on this bike but sadly I am out of funds and don't ride it.
Vespa ss90 / ss50
Vespa ss90 / ss50
Hi please can you post few Pics of the ss180, thanks!
@airfin avatar
some Vespas, some Lambrettas
@airfin avatar
this bike is sold....
Vespa ss90 / ss50
Vespa ss90 / ss50
[ Time: 0.0139s ][ Queries: 3 (0.0071s) ][ live ][ 313 ][ ThingOne ]
