The turn signals and rear running lights are out and I don't know what device (relay/regulator) has failed or where the heck it is located. I have read what to check for...but not where it is ....don't you know either?
Thanks much in advance
jim
2006 150LX BLACK METALLIC
Posts: 48 Location: EL DORADO HILLS, CALIF |
Thanks much in advance jim |
where can I get one, and is it the unit to the right of the horn on the lx 150 2006? thanks again jim |
Before you go the expensive replacement route, have you checked your fuse?
It looks like this: http://www.scooterwest.com/items/?_pageCCS=t#page=/item_details/ET4-LX150-CDI-Unit-(Un-programed)/4464 ⚠️ Last edited by Scooter West on UTC; edited 1 time
Motorsport Scooters wrote: The turn signal relay is incorporated into the CDI. It's not a standalone unit. |
S 150, VNB 150, 101 Allstate, 01 ET2, 2005 PX
Posts: 1504 Location: CT |
orange s150 wrote: not to interupt but what do they do for the S then? i have wonderd this for a while. |
Posts: 15123 Location: The state of insanity, SoCal |
max hit it on the head-- generally the circuit in the cdi fails causing the signals to go out-- however, check your battery and fuses first.
that being said, also check the connection at the cdi. i had one that was not making contact on that particular pin.... best, -greasy |
Wiki Moderator
Posts: 6916 Location: Los Angeles |
greasy125 wrote: max hit it on the head-- generally the circuit in the cdi fails causing the signals to go out-- however, check your battery and fuses first. that being said, also check the connection at the cdi. i had one that was not making contact on that particular pin.... best, -greasy |
Resident Gentleman
Posts: 5047 Location: Brady, TX |
Motorsport Scooters wrote: Before you go the expensive replacement route, have you checked your fuse? It looks like this: http://tinyurl.com/ET4-LX150-CDI-Unit-Un-program |
I don't know what difference a day makes..but....The blinkers are working again I was checking what was working and what wasn't working so I could tell the dealer.....I turned on the key and the blinker was working...no problem
Thanks for everyone's help on this jim |
