Hello All,
Has anyone replaced the Clutch indication switch on a modern PX150 without disassembling the entire handle bars? I have a PX150 that doesn't reliably start with the electric starter. The Relay tests good when bench tested and it appears that the switched ground connection of the neutral switch in the handlebars is faulty. I don't want to disassemble the entire left handle bar to replace it there is an easy way to remove the nut and fish another one in.
Any help or experience in this area appreciated before I remove the entire left handlebar and have to adjust clutch, shifting, etc.
SanJoe
