Malossi kit from MotorSport San Diego, including adapters, valve, Dellorto 30mm carb.
First you have to remove material from inside the case. This shows where following their instructions (poor instructions) then the result.
Next you have to enlarge the intake port and match the adapter pieces so you have a smooth flow into the case. Also on this kit you have to clear an area so the adapter can bolt square onto the case.
The throttle and choke cables that come with the kit need to be carefully cut to length and are a pain of trial and error. The bellows that comes with the kit is too short. I made an adapter from a piece of PVC 45 degree water pipe, and used a standard bellows. It bothers me a little that there is no air filter, but I will probably adapt a furnace filter and install it inside the body cavity.
Here is what the kit looks like before installation. (except for the base plate)
I have 300 miles on the run in and it feels very strong, but I am keeping under 45. Can't wait to open it up.
