Ok ok ok, so here's the exciting news....
Its definitely 2 separate issues.... I've solved one....and I think I've got the answer for the other!!!
As you will know...when I went out to test what I'd done with swapping the plugs last night, I was very disappointed when it seemed to make absolutely no difference, the idle seemed to be getting worse as the scooter was warming up. The last thing I noticed when coming to a stop and trying to keep the revs on whilst negotiating the scooter into the garage at home was a misfire.
I thought nothing more of it, but then at work I started to think...what if it was 2 separate problems that i was facing after all, one being spark related (the idling problem) and the other being fuel supply starvation of some sort (the mid-range stumbling).
So I thought that if I tackled the spark plug side of things first then at least I could get the scooter running without it constantly cutting out.
So I decided that because the spark plug I'd fitted was brand new (only this month) then that should (in theory) not be the fault. So I decided I would try to diagnose my idle/spark problem by progressing onto the next step in the "spark chain".... testing and swapping, and then onto the next item until I found what was wrong.
I enlisted the help of a colleague at work to try to find a spark plug cap at short notice as I wanted to get it up and running as soon as I could. I work as the Finance Director of a motor dealership so I asked the parts manager if he could source me one from one of his suppliers, I had forgotten to make a note of the part number like a fool... so i sent him off on a bit of a wild goose chase (unfair of me I know!).
Anyway, he returned fairly quickly with a choice of two on a Sale-or-Return basis, "Just bring me back the one you don't fit and I'll get a refund for it".
So when I got home tonight I removed the old one and fitted the VB05F plug cap and then refitted the new spark plug...and then went for a run.
I scooted for over an hour, and experienced not one idling problem, neither while hot nor cold, neither after running flat-out or "pootling", so to say I'm chuffed would be an understatement.
Total cost of the repair.... £2.60.... Yay!!
So...onto problem number 2....
Assuming that that the problem with the mid-range stutter was now a fuel supply issue of some sort, I started to re-read the posts that you all had left me in this thread and also in the the other thread>>>
GT125 + Scorpion Exhaust and I tried to eliminate in my mind which it may now be and which it definitely wasn't. With sorting out the idle problem I was now fairly certain that spark related theories were now not right.
Three posts made a lot of sense, now that I was looking at them in a different light...
1) One was about fuel pumps but my thoughts are that a fuel pump failing would be across the throttle range and not just mid range.
2) The second post that I focused on was about spark plugs but more in the sense of "that's what you last messed with before it broke" and that made a lot of sense so I've considered what else I've messed with and I'm thinking that the Scorpion exhaust may have something to do with it.
3) Thirdly was the post about mid-range flat spots and shimming the carb needle with washers to make it run more rich mid-throttle, and I figured that the Scorpion may need that.
So what I did was to remove the needle and shim it with 3 small stainless washers as suggested and take it for a run out again (about 30mins).
What I did notice was that the idle was still good throughout the whole run, but even more interestingly was that the stuttering was more apparent at 3/4 to WOT, it had moved up the range from mid-throttle!!
I'm thinking that I need to change the main jet up a size or two perhaps to "feed" the new exhaust which I'm guessing is being a bit starved, I havent had chance to plug chop with the other problems going on.
What are your thoughts??
Fabio
