Tue, 17 Jan 2006 01:23:14 +0000
BV500
BV500
Tue, 17 Jan 2006 01:23:14 +0000 quote
Here's some pics of the wasp. Be gentle this is my first attempt at editing and posting photos on the forum.
FM Radio Antenna
Wasp Decals (source of Avatar)
Italia Grille Badge
Tue, 17 Jan 2006 09:38:25 +0000
None! I sold it :(
None! I sold it :(
Tue, 17 Jan 2006 09:38:25 +0000 quote
I like it very much! Gotta know more about the radio, Beale.
Tue, 17 Jan 2006 15:44:58 +0000
NONE (At this moment)
Tue, 17 Jan 2006 15:44:58 +0000 quote
Enlighten us on the radio? Please.
VESPARICAN 8)
Tue, 17 Jan 2006 18:33:02 +0000
2006 GT200
2006 GT200
Tue, 17 Jan 2006 18:33:02 +0000 quote
nice pics Chris!
where did you get those cool wasp stickers?
Bernie
Wed, 18 Jan 2006 00:29:47 +0000
BV500
BV500
Wed, 18 Jan 2006 00:29:47 +0000 quote
Thank you. Bare with me here, this might be long winded, and I will attempt to explain how the radio is set up.
The radio project was based on a couple of assumptions;
1) For safety I needed to be able to hear the traffic
2) As the bike is brand new I didn't want to cut, drill, or alter the body/wiring.
3) No cables or wires to come loose in the wind or interfere with driving.
After ruling out using the glove box, under the seat and the top box to mount a radio, for the reasons above, I took a trip to the local Radio Shack and came up with a small 2" portable radio designed I believe for joggers. The key is that it has a belt clip that will fit on the passengers seat strap. Handy and secure. Here's a link.
http://www.thesourcecc.com/estore/Product.aspx?language=en-CA&catalog=Online&category=Personal+Radios&product=1218247
I'm sure there are many other types out there and you may have something kicking around that will do. I picked this one based on the quality of Grundig...I already have a portable shortwave that has excellent sound and range.
It came with ear plugs and the connector wire acts like an antenna, but there were two problems. The ear plug didn't stay in my ear very well and out of the city the signal weakened if I moved around, so the unit would scan to the next station.
So I decided to install an antenna which looks pretty cool on the GT and also found an old set of headphones that one side wasn't working.
The headphone was small enough that it fit in the ear webbing of my 3/4 helmet chin strap, and when I did it up fit snuggly in place. Really good quality sound much better than the earplugs I tried. So I removed the one good ear muff from the head band and cut and stripped the wire from the other side back almost to the plug to accommodate the antenna cable. To the bare wired I soldered a female 1/8" stereo plug connector.
To go to the antenna I used a 1/8" stereo patch cable and cut one plug off to attach a battery type wire connector the size to fit over a 6mm (1/4") bolt. This bolt screws into the bottom of a standard one piece antenna whip.
The antenna was mounted on a piece of plexiglass 1/4" thick x 26" long x 1" wide, like and arm projecting out from under the top box. I choose this material because I wanted to heat it and bend it up at the underside end to mold to a slot under the rack giving it more stability and also to bend it parallel to the ground near the antenna end as the top box is on an angle and the the antenna was leaning forward.
To mount the arm I slotted it and used the same bolt as secures the top box (leaving out a washer that was on the inside to give it enough clearance.) I couldn't find a 6mm x 60mm bolt locally that would be long enough. Drilled a hole at the other end of the plexiglass arm to mount the antenna.
Everything was fine but the arm was flexing too much so I broke one of the rules and drilled and used two self tapping screws through the arm into the rack, between the top box bolt mounting bolt and the end of the box towards the antenna.
I've had it up to 120 kph on one of our warmer days and the antenna of course bent with the wind but was very secure.
All in all I'm very pleased with this set up. I hope you could follow this horrible explanation. As soon as the weather gets better I will take some close up pics of the radio connections and under the top box and post them.
Wed, 18 Jan 2006 00:43:17 +0000
BV500
BV500
Wed, 18 Jan 2006 00:43:17 +0000 quote
Re: nice pics Chris!
Bernie
Sorry Bernie I got so into the trying to explain the radio thing that I forgot you. I got the decals of the internet "DecalMax.com" I can't remember but I'm pretty sure you can get the prices in both US and CDN $. The yellow highlights I did with a permanent marker pen as it was in black and white only.
and thank you for the compliment, I really struggled trying to get the pics within the size limit for posting
Wed, 18 Jan 2006 01:03:22 +0000
Wed, 18 Jan 2006 01:03:22 +0000 quote
Wasp Rider
You just need one of these now. Thanks for the Decal Max site.
Tim
Wed, 18 Jan 2006 21:40:35 +0000
Vespa GTS 250 i.e.
Vespa GTS 250 i.e.
Wed, 18 Jan 2006 21:40:35 +0000 quote
The Italian badge on the front is a nice touch.
Wed, 18 Jan 2006 22:36:33 +0000
Wed, 18 Jan 2006 22:36:33 +0000 quote
badge over horn cover
keep an eye on the voltage regulator, it sits right behind the grill where you pat the badge. supposed to be kept cool, i am not certain but it might overheat with the badge blocking it.
  DoubleGood Design
[ Time: 0.0380s ][ Queries: 4 (0.0167s) ][ Debug on ][ 299 ][ Thing Two ]
