Is the body SN located anywhere else but behind the top of the "carb" door?
On the VS5 I just bought, the paint is so pretty at that location it is a shame to buff a slot.
![]() '60 Allstate VNB1, '60 GS150 VS5, '61 Cushman VBB1, '62 GS160 Mk1 VSB1, '64 GL VLA1, '74 Rally VSE1 200 Euro, '78 P200e VSX, '06 LX150
Posts: 814 Location: Half Moon Bay, CA |
Tue Aug 16, 2011 7:38 am
1952 Allstate, 1955 VL1, 1953 VM1, Sprint Veloce, 1966 SF Blue Badge
Posts: 183 |
Posts: 183 |
![]() 74 Rally 200 - 70 Sprint Veloce - 68ish Bajaj VBA - wifes 1970 V90 - 77 NYPD Sprint Veloce
Posts: 340 Location: Atlanta |
![]() Wed Aug 17, 2011 9:56 pm
Posts: 5779 Location: Indo |
![]() a not so normal vbb2 '64, a weirdo vbx '86, a not so normal pts100 '82 and a yellow sunshine '74 sprint
Fri May 06, 2022 4:48 am
Several vespa's
Posts: 6 Location: Amersfoort |
Hi,
Really old topic but hope someone is able to help me;-) Just bought a GS 150 (VS5) which has been standing still for 52 years but I can't find the framenumber anywhere (not even a single letter or anyrhing. I have only seen VS5 where the framenumber is behind the carb door. I have the first original papers from the scoot and this documents says: framenumber under the glovebox. Happy that you guys confirmed this that VS5 switched the location of the framenumber during production. I attached 3 pictures : -1 from behind the carb door - 1 under the glovebox - 1 from under the glovebox where the IGM number is cleary visible. Had GL's before where the number was almost completely gone under the glovebox because of rust and mud in the years of the sparewheel but it seems strange to me that the IGM number is in perfect shape and then the framenumber will completely be gone? Do you guys knows VS5 where the framenumber was on a different location? Even checked the engine side (location of large after '65) but nothing. Best, Peter ![]() |
Fri May 06, 2022 4:49 am
Several vespa's
Fri May 06, 2022 4:50 am
Several vespa's
Fri May 06, 2022 4:52 am
Several vespa's
![]() GL, PK, PE200 with hack, Sears Rust Badge
Posts: 1276 Location: Deep in the heart of Texas |
Look on the backside of frame under the IGN number. Should have the stamp impression of the numbers. Prob can use some paper with black chalk/mark to get a better impressions of numbers.
Try other locations behind the frame near the carb door, too if not in the back of scooter. If not under those location could be replacement frame. |
Sat May 07, 2022 4:09 am
Several vespa's
Tue May 10, 2022 10:09 pm
Several vespa's
