Sun Aug 21, 2011 12:46 pm
Piaggio MP3 125
Piaggio MP3 125
Sun Aug 21, 2011 12:46 pm linkquote
Hi everyone;
I have a problem with my MP3! A weird squeaky noise is coming from the front of the bike when i lean left or right! Its like a door hinges that needs oiling!
I never had that problem before, it only started today! I sat on my bike and without starting the engine i leaned the bike slightly and immediately heard this squeaky noise!
I am wondering if that happened to any of you and if you know what might be the problem?
I rode it for 10miles and the noise is there! Do we need to oil any parts of the suspensions?
Any help is appreciated.
Many Thanks...
Sun Aug 21, 2011 6:13 pm
Two - 2009 Genuine Buddy 125s
Sun Aug 21, 2011 6:13 pm linkquote
Sorry to hear that!
I'm not a mechanic, but for those that are mechanically inclined:
What year is your scooter, and how many miles are on it?
Is it still under warranty?
I don't know how many MP3 125 owners are on the forum...
Mon Aug 22, 2011 1:33 am
Piaggio MP3 125
Piaggio MP3 125
Mon Aug 22, 2011 1:33 am linkquote
Hi;
It is year 2008 with 20000km on it and no warranty!
Mon Aug 22, 2011 12:08 pm
Piaggio MP3 125
Piaggio MP3 125
Mon Aug 22, 2011 12:08 pm linkquote
Seems like no one had the same problem!..
I booked in for a check up tomoro at local dealer. Might also get it serviced while there.
I will also ask them to inspect the whole bike for any problems and let you guys know the outcome...
Thu Aug 25, 2011 6:19 am
MP3 500
MP3 500
Thu Aug 25, 2011 6:19 am linkquote
It's most likely the rotor for lack of better name, used to lock the front end. It's sliding between the pads as you lean it back and forth. It works just like a disk brake set up.
Thu Aug 25, 2011 6:28 am
Moderatus Rana
MP3 250 (sold) MP3 500 (current)
Moderatus Rana
Thu Aug 25, 2011 6:28 am linkquote
When I make sharp low speed turns to the left I hear a noise coming from the right front which I think is the rotor rubbing slightly on a brake pad. It has done this since it was new so I don't worry about it. It is not really a squeak, more like a low rubbing noise.
Thu Aug 25, 2011 8:54 am
Piaggio MP3 125
Piaggio MP3 125
Thu Aug 25, 2011 8:54 am linkquote
Thank you guys, thats a relieve!..
I took my bike back from the garage yesterday. They charged me an hour labour for just to clean the clutch ( there was a grinding noise coming from the back whenever i take off) and done nothing in the front!..
They said there was dust between suspension and they cleaned it!.. However, it is still making the noise.
And the noise only comes if i press down the front brakes and lean the bike left or right. It is quite loud but if you guys say nothing to worry about than im happy Never happened before or maybe i never reallised it was there...
Cant explain how relieving that is as i was scared something was going wrong!..
Thank you very much guys
Thu Feb 16, 2017 4:36 am
Thu Feb 16, 2017 4:36 am linkquote
mine (500 abs) does it as well after 3000m. It is not audible when the engine is on, I can only hear that faint "metal rubbing metal" sound if i lean the bike (trike) while the engine is off. Steering, leaning are not affected.
Still, i reckon some well placed lube would make that sound go away.... but i do not know what to lube....
Sun May 23, 2021 10:00 am
Vespa ET2, MP3 250ie
Sun May 23, 2021 10:00 am linkquote
I have an 2008 MP3 250 with just over 4000 miles. I just noticed this squeaky rubbing sound when I lean the bike to the left it feels resistance also like friction. Only noticed it just now at a stop and when Iím leaning the bike slowly. If I speed up my tilt it goes away. Will check if I feel it while riding.
  DoubleGood Vespa Scarves
[ Time: 0.0382s ][ Queries: 22 (0.0194s) ][ Debug on ][ 156 ][ Thing Two ]
