Wed, 28 Sep 2011 03:04:42 +0000
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
Wed, 28 Sep 2011 03:04:42 +0000 quote
Did an assessment of the damage from my off. Got away very lucky. UFP saved me a bunch of money and headaches. No broken tupperware or tabs except for the bits under the floor board. Pulled off the bracket and using a vice and a hammer straightened it up. It had a twist so I put my big crescent wrench on it and got most of it by banging the wrench. Still a little more squish than it used to have but usable. I would say it is 90 percent back. Doug suggested adding diamond plates and that would probably do it. Oh the forward screw had a slight bend to it.
Here are some pictures.
Broken Tupperware under the foot rest.
Shows the bend and the twist.
Another shot of the bend with my scraped up foot peg...the scrapes have nothing to do with the crash. :)
In the vice.
Straight after banging on it with a small sledge hammer.
Still had a twist so I put a big crescent wrench on it and banged it almost back to original.
Finished...almost like new.
Back on the scoot.
Wed, 28 Sep 2011 03:34:16 +0000
NC700XD
NC700XD
Wed, 28 Sep 2011 03:34:16 +0000 quote
Not bad at all. Glad to hear you're back to 98-99%! Just remember, chicks dig scars. Or stories about scars... I think the actual scars kinda creep them out a little. Actually, you know what? Chicks are crazy, I have no idea what they dig. I suspect they don't either sometimes...
Wed, 28 Sep 2011 03:41:44 +0000
MP3 400
MP3 400
Wed, 28 Sep 2011 03:41:44 +0000 quote
Chicks actually dig worms, at least when they're felling a bit peckish.
Wed, 28 Sep 2011 05:46:29 +0000
Previously:Fuoco 500ie with Active Suspension. Now: CTX700
Wed, 28 Sep 2011 05:46:29 +0000 quote
Hi sticky.
I had to do a repair to the tupperware:
You can see the crack to the left of the patch. I fibreglassed the back (which you can't see) then put a cover patch on the front and drilled thru the patch, the tupperware and the fibreglass, then pop-riveted the whole assembly together. The reason I pop-riveted it is that bugger-all sticks to the ABS.
Just thought it may help your repairs.
Gonzo
Wed, 28 Sep 2011 12:00:23 +0000
2007 Yamaha Vino 125
Wed, 28 Sep 2011 12:00:23 +0000 quote
Glad you got it all straightened out, Sticky (Pun intended)
Good luck figuring out how to fix your broken plastic there. I've just recently had mine apart, and I really don't know what you'll be able to do...
Wed, 28 Sep 2011 12:23:40 +0000
Moderatus Rana
Moderatus Rana
Wed, 28 Sep 2011 12:23:40 +0000 quote
Great idea Gonzo. Will have to yank it apart and see if I could do something similar.
Wed, 28 Sep 2011 12:38:33 +0000
Moderatus Rana
Moderatus Rana
Wed, 28 Sep 2011 12:38:33 +0000 quote
Just bought two used diamond plate floor boards. Hope they help. Thanks for the link OAD.
http://cgi.ebay.com/ebaymotors/?cmd=ViewItem&_trksid=p3984.m1423.l2649&item=330541090147&sspagename=STRK%3AMEWAX%3AIT
Wed, 28 Sep 2011 12:59:01 +0000
RIP: MP3 500 - Brutto Moto
Wed, 28 Sep 2011 12:59:01 +0000 quote
Mine was a little "soggy" after my mishap and I finally tracked it down. Mine cracked the silver tupperware on the bottom. I discovered that it has tabs that added rigidity to the floorboard. Busted. But - there is a lip going inward and I drilled a hole and put a machine screw in there. Much better. I also busted the tab inside the fuse access there. Quite a bit of damage actually in busted tabs and whatnot. Not enough for me to lose sleep or worry about replacing tho...
Wed, 28 Sep 2011 17:12:13 +0000
Wed, 28 Sep 2011 17:12:13 +0000 quote
So are your showing us your damage or showing off how much you have been scraping your pegs.
Wed, 28 Sep 2011 17:13:42 +0000
Moderatus Rana
Moderatus Rana
Wed, 28 Sep 2011 17:13:42 +0000 quote
Caught me.
Wed, 28 Sep 2011 17:17:37 +0000
Wed, 28 Sep 2011 17:17:37 +0000 quote
stickyfrog wrote:
Caught me.
Draggin pegs is a source of pride my man! Nuttin to be embarrassed about there.
Wed, 28 Sep 2011 17:36:39 +0000
Moderatus Rana
Moderatus Rana
Wed, 28 Sep 2011 17:36:39 +0000 quote
BubbaJon wrote:
stickyfrog wrote:
Caught me.
Wed, 28 Sep 2011 18:34:42 +0000
Honda CTX 700D
Honda CTX 700D
Wed, 28 Sep 2011 18:34:42 +0000 quote
stickyfrog wrote:
BubbaJon wrote:
stickyfrog wrote:
Caught me.
Thing is .... are they scraped equally on each side?
Wed, 28 Sep 2011 18:58:58 +0000
Moderatus Rana
Moderatus Rana
Wed, 28 Sep 2011 18:58:58 +0000 quote
Yeah pretty much. Maybe a little more on the right since I have a really nice right turn on my ride home when I shoot over to get the mail.
Thu, 29 Sep 2011 01:47:11 +0000
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
Thu, 29 Sep 2011 01:47:11 +0000 quote
Superb job, Sticky, I've linked the UFP maintenance FAQ to this thread. Many thanks. If you want a replacement screw just ask.
Some of the ideas posted here are potentially very useful and not specific to just the UFP, so I've added this thread to Speedskater's spreadsheet. Great stuff.
Thu, 29 Sep 2011 12:11:27 +0000
Moderatus Rana
Moderatus Rana
Thu, 29 Sep 2011 12:11:27 +0000 quote
Thanks Jeff. And thanks for the offer of the screw. I have to find some for the rear holes of the floor boards I ordered so I will look for a replacement for the bent screw too. I'll pm you if I can't find one.
Thu, 29 Sep 2011 13:17:16 +0000
MP3 500 - GTV250
MP3 500 - GTV250
Thu, 29 Sep 2011 13:17:16 +0000 quote
Wisdom, there.
  DoubleGood Design
[ Time: 0.0345s ][ Queries: 4 (0.0103s) ][ Debug on ][ 299 ][ Thing Two ]
