@quasi-moto avatar
SawStop
@quasi-moto avatar
SawStop
I was working on my project P200 yesterday and bump started it going down a slight hill. Towards the bottom of the hill I discovered the brakes don't grab very well...luckily I found out in time.
Since the lever felt okay, I pulled the hub thinking the scoot might need new brakes, but the brake pads look pretty good (see pic below.)
Should I abrade the inside of the hub a little, to get it to bind better?
@gickspeed avatar
@gickspeed avatar
Re: P200 brakes. Can I make them grab better?
new brake shoes. you would be suprised what they will do for you.
either sand the inside of the hub or media blast it completely.
those two things will work wonders.
@quasi-moto avatar
SawStop
@quasi-moto avatar
SawStop
I was thinking of new brakes, but doesn't it look like there ls lots of meat on the brakes? I expected to find much more wear.
@gickspeed avatar
@gickspeed avatar
does not matter. the lining (most likely asbestos) soaks up all kinds of nasties over time.
@quasi-moto avatar
SawStop
@quasi-moto avatar
SawStop
Ok then, easy enough to replace while I have it open. Thanks.
@jwilliams avatar
'60 Allstate VNB1, '60 GS150 VS5, '61 Cushman VBB1, '62 GS160 Mk1 VSB1, '64 GL VLA1, '74 Rally VSE1 200 Euro, '78 P200e VSX, '06 LX150
@jwilliams avatar
Wipe the shoes with acetone.
Lightly sand the shoe surface.
Wipe with acetone again.
Use some 120 grit sandpaper on the drum to remove any shiny places and get a consistent dull surface over all.
Wipe with acetone.
This usually restores Vespa brakes to their optimum (marginal) braking condition.
This did not work with my daughter's P200 so I installed new shoes. Better.
Installed a helper pully between the lever and hub mount. Much better.
Ain't disks but better.
@quasi-moto avatar
SawStop
@quasi-moto avatar
SawStop
Thanks Jim, that's good info. I did go ahead and order some new brakes, so will install them next week.
How does the helper pulley work?
@rwong709 avatar
2007 Vespa GT200
@rwong709 avatar
2007 Vespa GT200
New Brakes? Plenty of Lining Left...
Best thing to do is to change the rear drum brake shoe linings with new onces. Most OEM shoes are marginal at best...the compound generally does not see high temperatures they are designed for, so the compound gets glazed and surface hardened from modest use of short street riding trips.
I like to put a couple grooves in the linings with a hacksaw at a slant so road debris and such can be swept off the lining surface to eventually work their way out of the drums (old racer trick). Whatever you decide, don't forget to roughen the shoe lining and swept drum surface with sandpaper to allow the contact surfaces to "bed" properly. Use high temp grease on the metal pivot actuator surfaces and you will be golden.
Take digital photos of the assembly if you have not seen or done this before so you can identify all the parts locations, and note "sometimes" the shoes are NOT identical, so do take a note of their relative positions. Eye protection, brake spring tools, spanners, long nosed pliers and such may be needed as sometimes those springs are under considerable tension.
Cleanliness is paramount for a successful brake job. I use plain water and cup of water with old paint brush over newspaper to keep the dust down. Use no petroleum based cleaners...only use Brakleen to keep final metallic surfaces clean and dry. Handle the linings by the edges only...just lightly sandpaper them, groove 'em and install.
⚠️ Last edited by rwong709 on UTC; edited 2 times
@travisnj avatar
Primasarah
1979 P200E, 1977 Rally 200, 1974 Primavera
Primasarah
@travisnj avatar
@jwilliams avatar
@jwilliams avatar
I got this idea from the "projects" part of the MV website. This is not as pretty as his, but same idea.
The pully is from Ace hardware screendoor roller. The block I made from a hinge. The bitter end of the cable goes through a hole I drilled in the hub casting and secured on the forward side with a clutch cable clamp. You will need new brake pads to get enough space for this to work.
@pdxjim avatar
2005 PX150 In a Part-time Relationship with a 2-Stroke Vespa Since 2007
@pdxjim avatar
For sanding the drums and shoes to rough the surfaces I've always found emery cloth works ideal. And as above, get all dust and grit out using non-petro solvent.
1976 Super
1976 Super
Don't know how much this might apply to vespas but I just did it on my motorcycle. Make sure the arc of the brake shoe lining matches the arc of the drum and that you are getting full contact. If not you can put some sandpaper on the inside of the drum and sand your linings until you get full contact. Wear a mask when sanding your linings. It's not asbestos but could still be bad.
This might be overkill but thought I'd mention it.
@ginch avatar
@ginch avatar
kngkong wrote:
...you can put some sandpaper on the inside of the drum and sand your linings until you get full contact.
How do you go about doing that? Sounds good but I'm imagining sticking the sandpaper to the inside of the drum, fitting it back on and spinning it around by hand. That sort of thing?
I used to work at a (car) brake & muffler place and sometimes they would "radius" the shoes - clamp it in a swivelling contraption and rotate it past a sanding wheel. This would make sure there was full contact.
Thinking about it now, years later, there would have to be a correlation between the arc (made by the shoe in the clamp) and the radius of the drum.
What they said. Different thread, same subject. Making the most of out drum brakes?
Len's photo shows almost full contact on the shoe. The replacements I've tried had limited contact. It's almost as though the new ones were manufactured without the proper tolerances to make full contact. I could not see the difference by eye between the old and new. I finally resorted to a table mounted belt sander to try to radius mine.
Len, since you live in CA, you need to remove your shoes and send them to me for proper disposal. CA is no place for such hazards. 8)
1976 Super
1976 Super
Hey Ginch,
Tape or hold the paper in the drum and you can just sand the shoes by hand. Using 60 or 80 grit will sand down the linings pretty fast.
[ Time: 0.0119s ][ Queries: 4 (0.0051s) ][ live ][ 343 ][ ThingOne ]
