Tue, 28 Feb 2012 16:35:31 +0000
2010 GTS 300 SUPER
2010 GTS 300 SUPER
Tue, 28 Feb 2012 16:35:31 +0000 quote
Some years ago i bought a Tailmate brake light flasher.
Now it's broken and i want a new one.
Problem is i can't remember where i got it.
On the installation instructions is a site but it's "gone"....
www.brakeflasher.co.uk
It's a very small black cube about (3cm*2cm*1,5cm) (1,18inch*0,78inch*0,59 inch) with 3 wires connected red, yellow, black.
Does anybody know where to get it?
⚠️ Last edited by Progetto 300 on Tue, 11 Dec 2012 16:19:30 +0000; edited 2 times
Tue, 28 Feb 2012 17:51:37 +0000
⬆️    About 1y elapsed between posts    ⬇️
Tue, 11 Dec 2012 16:18:06 +0000
2010 GTS 300 SUPER
2010 GTS 300 SUPER
Tue, 11 Dec 2012 16:18:06 +0000 quote
Just wondering if someone saw this before...
⬆️    About 5w elapsed between posts    ⬇️
Mon, 14 Jan 2013 12:49:40 +0000
2010 GTS 300 SUPER
2010 GTS 300 SUPER
Mon, 14 Jan 2013 12:49:40 +0000 quote
Since it seems impossible to get the same brake light modulator, i got one from SMIDSY :
http://www.smidsy.biz
I've replaced all the bulbs with leds i can use this one :
http://www.smidsy.biz/ledbrakemodulator.php
As you can see here, it has a modus that holds the brake light on 30% of it's power so i creates even more light.
The package is small enough to fit in the rear light reflector near the sockets.
Mon, 14 Jan 2013 15:15:58 +0000
GTS250, P200E
GTS250, P200E
Mon, 14 Jan 2013 15:15:58 +0000 quote
I have a transmitter attached to the rear brakelight circuit, with the receiver and flashing LEDs on the back of my helmet. The receiver needs batteries only once per year. It's nice when following drivers give me an extra twenty feet of clearance at each stoplight. I still have to remember to turn on the receiver each time I ride.
Cheers,
Bob
Mon, 14 Jan 2013 15:49:52 +0000
GTS 125 I.E.
GTS 125 I.E.
Mon, 14 Jan 2013 15:49:52 +0000 quote
very interesting....
and where did you get that LED brake light ??
Mon, 14 Jan 2013 17:03:41 +0000
MP3 500 - Black Sunshine
Mon, 14 Jan 2013 17:03:41 +0000 quote
Buy the same basic thing from here. Flashes at 10 Hz (a "buzzing look") for 2 seconds, then goes solid red. Really catches your eye! The two wire install (cut the existing brake light wire, insert, seal) is nice, too.
I use it on my scoot and the brake visibility is much better, it definitely grabs your attention.
Tue, 15 Jan 2013 07:58:27 +0000
gts3001212
gts3001212
Tue, 15 Jan 2013 07:58:27 +0000 quote
Re: Tailmate brake light flasher
hey dude have you tried hyperlight from motorlarry?
Wed, 16 Jan 2013 16:44:36 +0000
FLY 150 / Vespa LX-150
⬆️    About 14w elapsed between posts    ⬇️
Fri, 26 Apr 2013 01:17:26 +0000
Vespa GTV 250 Cc Via monte napoleone
Fri, 26 Apr 2013 01:17:26 +0000 quote
size
im just wondering if this flasher from superBrightleds has the correct size to fit back of the light for GTV
I DONT SEE ENOUGH SPACE BACK
Mon, 29 Apr 2013 02:31:35 +0000
Gts super 300 '12
Gts super 300 '12
Mon, 29 Apr 2013 02:31:35 +0000 quote
I want this but would like to know which wire it attaches to? Thanks.
Mon, 29 Apr 2013 08:58:08 +0000
Mon, 29 Apr 2013 08:58:08 +0000 quote
The circuit diagram is shown in the link given above.
Mon, 29 Apr 2013 09:14:50 +0000
Vespa ET4 150, Ebony.
  DoubleGood Design
[ Time: 0.0394s ][ Queries: 4 (0.0178s) ][ Debug on ][ 297 ][ Thing Two ]
