None. I am a cager now.
Is this tutorial applicable to an MP3 400?
BV500: Replacing the Belt and Rollers
@mark_ii avatar
Yamaha XVS1100a
@mark_ii avatar
Yamaha XVS1100a
yep
good luck
if you got it apart think about what rollers to put back in.
quite a few articles in the forum to read
Mark Clown emoticon
Thank you. Any idea if the variator tool could be made from a less 16 gauge steel instead of 1/8" aluminum?
@mark_ii avatar
Yamaha XVS1100a
@mark_ii avatar
Yamaha XVS1100a
as long as it holds the screws in place to hold the vanes I dont see why not
rigidity the the key part
Mark Nerd emoticon
just buy a buzzetti vari tool from scooter west. very easy to use.
too expensive
lcstatema wrote:
too expensive
$53 too much for the right tool? ok then
yes
spend thousands on a scoot and you want to skimp on a proper tool. if you break the cooling fins it will cost you more than $53 to replace the vari. but its your scoot.
@fuzzy avatar
@fuzzy avatar
You won't even be the first one here to break them with this method. Listen to O.A.D.It is good advice.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
You gotta know when it is worthwhile to cut corners and when it is not...IMHO it is a not in this case.
[ Time: 1.0332s ][ Queries: 4 (1.0229s) ][ live ][ 313 ][ ThingOne ]
