@wanderingpurist avatar
MP3 500ie
MP3 500ie
hi,
I'm from the Italian school od driving - what's behind me doesn,t matter and I just drive forward!
afterall, the world is round, right? just keep driving forward and stop behind where you started from...
seriously, when I first got my MP3, I just duckwalked backwards, engine on or off. but I noticed mechanical resistence engine on, and remembered there is no manual clutch, engine and tranni always engaged ? and just slipping...
so I started shutting off the engine before going backwards.
any thoughts on the right way to back up, and the mechanical reasons behind it?
thanks in advance.
there should be no resistance with the engine off, ensure you are not dragging the brake levers or have the parking brake on.
with the engine running and the tilt lock on again you should have no resistance unless your dragging a brake lever.
with the engine running and tilt lock off your in the dog paddleing mode, be sure your not unintentionally throttling up and just regular idle.
@heinlein avatar
MP3 500, Ducati ST4s, Honda Silver Wing
@heinlein avatar
Re: newbie question: how do you back up an MP3 or any CVT bi
WanderingPurist wrote:
When I first got my MP3, I just duckwalked backwards.
If I'm backing out on a nice flat parking lot; I prefer to leave the tilt lock on and walk beside it with one hand on the back and one hand steering.
But I noticed mechanical resistence engine on, and remembered there is no manual clutch, engine and tranni always engaged ? and just slipping...
thanks in advance.
I'm ignorant in this area so I will leave it to the more knowledgeable among us to answer that part.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
Have never felt any resistance pushing back with the engine running.
I fell a slight resistance when it's cold outside and the engine's cold - as its idle revs are a tad under 2,000 at that point and the clutch begins to slip. This may vary from bike to bike.
When the bike's warmed up there shouldn't be any resistance paddling backwards.
@welcha avatar
'Sophia' - Demon Black MP3 500
@welcha avatar
Perhaps his idle is running a little high? That would engage the belt ever-so-slightly...
Scarabeo 500GT(hers), `07 250 MP3, `09 400 MP3
Maybe his road isn't flat like he thinks.
MP3 500ie
MP3 500ie
so there should be no issue with backing
when the engine is running? belts arent slipping like they're not supposed to?
thanks for all the comments.
Randy, unless I,m on meds or drunk, I can usually tell rolling resistence from mechanical resistence. and I dont drink and ride.
Re: so there should be no issue with backing
When you're back pedaling, it doesn't take much of a slope to maybe think your MP3 has a problem instead of the operater. If you get off the MP3 locked upright and push it backwards, you will then know if there is MP3 drag. My driveway has just enough slope that if my MP3s won't coast backwards, it tells me the rear tire is low on air. Clown emoticon
2007 MP3 250(retired) C650GT
I occasionally notice resistance first thing in the morning, as I'm backing out of the carport. The weather is usually nice, and I'm like, "Damn, I don't want to go to work today." I guess the resistance is all in my head. Clown emoticon
That could be caused by flat spots on your tires if they have nylon in them. Nylon belted tires temporarily get a flat spot when sitting for awhhile. Not until they roll awhile are they perfectly round again. Nylon construction is for longer wear. Nerd emoticon
@mpfrank avatar
@mpfrank avatar
How do you back up an MP3?
The same as any file. Just copy it to a portable hard drive, or use an online data storage service.
Sheesh!
Clown emoticon
@heinlein avatar
@heinlein avatar
Sheesh!
Clown emoticon
Laughing emoticon
The rest of us must be slowing down to have missed that one.
@sanogeo1 avatar
Red Mp 3 500
@sanogeo1 avatar
Red Mp 3 500
I too, Have noticed a little resistance, But only when it is cold, and I am just starting out. No problem after the scoot has warmed up.
@bravotwofour avatar
'09 Mp3-500 - Gone Now
This is where the tilt lock really shines. I use the method heinlein describes, and rarely paddle backward with the engine on - too easy to throttle or hit the tilt lock switch. Being able to push the scoot around like a shopping cart when parking (or unparking) is a major feature of the design. Just have to be cautious on hills / cross grades.
@heinlein avatar
@heinlein avatar
If you are going to do it with the engine running I suggest doing it from the left side to minimize the likelihood of a mishap.
Makes sense, good point. I can't recall having done it that way meself.
@rjeffb avatar
Bracketmeister
Bracketmeister Emeritus (retired)
Bracketmeister
@rjeffb avatar
W.P., it seems to me that there's a simple experiment to nail this down. The next time you're waddling backwards and you are feeling resistance, just turn off the engine.
If there's no change, then there's a non-engine issue like your brakes are slightly engaged or your tires are low or have a flat spot - or the ground is simply not as flat you you thought it was. If there is a difference, then your belt is dragging slightly at idle, which could be a warped clutch bell, clutch springs, or (most likely) too high an idle. Either way, you'll have a better idea of what to do.
@sanogeo1 avatar
Red Mp 3 500
@sanogeo1 avatar
Red Mp 3 500
Too high an idle make sense, Mine idles higher until warmed up.
MP3 500ie
MP3 500ie
great idea, makes perfect sense. thanks.
Piaggio mp3 500
Piaggio mp3 500
First hand experience last Sat. March 3
Get off the bike on the left side. Do it on the right side and you are in danger because you will likely touch the tilt switch and then you have "A PROBLEM". I did and it slowly went down. Couldn"t hold it up. Never send it backward from right side!!! I always get off and hold on to the side bars and handle bar. Never again from the right side!!!
@heinlein avatar
@heinlein avatar
I wish you had read my post in this thread from the day before so it wouldn't have happened to you; but if you're going to have a bike laying on it's side this is one of the least painful ways.
@blue avatar
Piagio MP3 250
@blue avatar
Piagio MP3 250
I try to pull in forward if forward is up hill so backing is easy, and back in if parking is downhill, if lot is neutral I look for a spot to pull straight through. I park in a shed at night and back in I have noticed less resistance when the engine is running but also have accidentaly hit the throtle defeating my backing by lurching forward. I find it easier to paddle foot it than to try to push while off the bike. ( I have droped it a couple of times trying to push it fro the side, sliped on some lose material the first time then picked it up only to have it fall the other direction.)
@sanogeo1 avatar
Red Mp 3 500
@sanogeo1 avatar
Red Mp 3 500
I usually lock the tilt lock and turn the key off. Sometimes I have had to unlock the tilt when moving it around, But then I re-lock it and turn the key off. Only time I remember using the rocker switch was when the scoot was laying on top of me. the old parking brake and tilt lock got me. Anyway by using the key to kill it, I don't have to worry if I hit the tilt unlock by accident. I don't like to paddle it. I usually push it from the left side with the tilt lock on if possible.
@ponydrvr avatar
Honda CTX 700D
@ponydrvr avatar
Honda CTX 700D
+1 I learned very early on to turn the ignition off after setting the tilt lock to prevent an accidental release while pushing or pulling it to a parking space. IMHO it the only way to prevent accidental spills.
[ Time: 0.0252s ][ Queries: 3 (0.0109s) ][ live ][ 313 ][ ThingOne ]
