@markypost avatar
1.Retired Pre-Lead ET4 2.Retired Lead ET4 3.Retired GT200 4.Retired GTS125 5.Retired GTS300S 6.Retired LX50 7.Current GTS250ie
@markypost avatar
Hi guys,
I'm planning on doing a lil project and I'm looking for a 250 engine,
I understand that I can also use the MP3 250 as they're all interchangeable.
Also, I'll be looking to swap the engine on my GTS125. Is it a simple plug and play type swap, or are there anything else that needs doing?
Anyone know of one or any suggestions to a breakers?
I've scoured through eBay, lots of breakers websites(to no avail), I also saw one on Gumtree which said it was a GTS250 engine, then I notice the ad detail mentioned it was from an 04' plate which means it must have been a 200.
any leads..?
thanks guys!
@gregshooter45 avatar
2006 & 2007 GTS 250ie, 1975 Rally 200
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
gts 250 won't go into a GT125. well, it could, but you would practically have to strip the bike to the frame and rebuild it.
you need to swap the whole wiring loom, fuel tank, dash, engine and cooling system. not a straight engine swap at all. could drop a GT200 engine into it with no drama if you want.
@markypost avatar
@markypost avatar
Thanks for the look
But I'm in London!
I'm sure shipping will cost me an arm and a leg!
@markypost avatar
@markypost avatar
I've got a GTS125 not GT125
I understand fitting it in the GT will be different, but will it still be the same for a GTS125?
@dougl avatar
El Macho
KTM Super Duke 1290, Vespa GTS 300
El Macho
@dougl avatar
Yes, the GTS125 is a GT in all but name. If you want to see what is involved, TheO.Z. fitted a GTS engine to his GT200. Same thing required for you. New loom, tank, fuel pump, dash and all the other bits and bobs.
[ Time: 0.0423s ][ Queries: 3 (0.0347s) ][ live ][ 313 ][ ThingOne ]
