Is it possible to fit these 13 inch wheels to a GTS?
To compensate the extra diameter i would use a tire with a lower profile like a 130/60-13...
Any ideas?
![]() Sun, 04 Mar 2012 10:34:44 +0000
2010 GTS 300 SUPER
Posts: 1524 Location: Belgium |
![]() 2010 GTS 300 SUPER
To compensate the extra diameter i would use a tire with a lower profile like a 130/60-13... Any ideas? ![]() |
![]() 2016 Honda NC750XD, 2007 GTS (sold),
Posts: 3517 Location: Canada |
Sun, 04 Mar 2012 11:02:58 +0000
Some folks run a 140/70 R12 rear for a higher top speed- 140/70/12 on gts?
And if this is believed- Tire Calculator your proposed setup is smaller. But, I think I'd prefer 140 R12 rear rather than going for than 13 inch rim. The 140's been well tested and the cost of replacing just the tire is probably cheaper than both a new rim & new rubber. |
![]() Sun, 04 Mar 2012 12:06:19 +0000
2010 GTS 300 SUPER
![]() Sun, 04 Mar 2012 13:20:57 +0000
1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
Posts: 6064 Location: Northants UK |
![]() 1975 Vespa GTR 125, 1976 Vespa V90 (Resto), 2001 Vespa ET4 125 (Sold), 2009 Vespa GTS300 Super
If you're thinking of doing a 1:1 wheel swop you also need to check the wheel bolts will fit your existing GTS hub OK - parts may be consistent from between Piaggio models but I'm not sure. Be mindful of braking performance too on a changed setup.
![]() Sun, 04 Mar 2012 20:26:15 +0000
2006 GTS 250ie in Silver
Posts: 1808 Location: Bend, OR |
![]() 2006 GTS 250ie in Silver
Also the offset of the wheels might be different on the hub. This might look great and I would love to see a shop try it out first.
scooterless
Posts: 2085 Location: Googleville |
Mon, 05 Mar 2012 17:12:36 +0000
Re: 13 inchers on a GTS
LX125 wrote: To compensate the extra diameter i would use a tire with a lower profile like a 130/60-13. What bike is that? Pretty sure it would work, Piaggio uses the same hub on everything. Verify by crossing the hub part number. Slight offset difference if any is non-issue as long as nothing hits. Might have just shown me my next Vespa -- 300 Super with those, Bitubos and a Akra would be sweet. |
![]() Tue, 06 Mar 2012 10:23:35 +0000
2010 GTS 300 SUPER
bluecloud wrote: What bike is that? Might have just shown me my next Vespa -- 300 Super with those, Bitubos and a Akra would be sweet. 2 That's my idea ! |
![]() Tue, 06 Mar 2012 11:16:15 +0000
Are you sure the rims in your orginal pic are 13"s?
All the MP3 specs I see say 12" rims? |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42942 Location: Pleasant Hill, CA |
Tue, 06 Mar 2012 12:25:46 +0000
brown_beret7 wrote: Are you sure the rims in your orginal pic are 13"s? All the MP3 specs I see say 12" rims? |
![]() Tue, 06 Mar 2012 14:43:30 +0000
jimc wrote: brown_beret7 wrote: Are you sure the rims in your orginal pic are 13"s? All the MP3 specs I see say 12" rims? |
scooterless
Tue, 06 Mar 2012 16:59:08 +0000
Michelin Pilot Sports available in 130 and 140/60-13, only a couple 10ths larger dia. than stock 12s.
![]() Sat, 10 Mar 2012 08:14:44 +0000
2010 GTS 300 SUPER
brown_beret7 wrote: Be mindful of braking performance too on a changed setup. |
Sat, 10 Mar 2012 08:47:08 +0000
If overall diameter of tyre does not change, there should not be any changes to brake performance.
![]() Sat, 10 Mar 2012 16:23:09 +0000
Posts: 22336 Location: Harriman, Tennessee, Tn |
![]() 2007 GTS
same hole pattern as on the 12" rims. just need to check diameter clearances . but should be just fine. You could find a yourban owner willing to let you use his rims for a test fit before you buy new rims.
![]() Sat, 20 Apr 2013 18:51:37 +0000
2010 GTS 300 SUPER
Finally got my 13 inchers shod with Conti Twist Sports & 15 mm white reflective striping.
![]() Various
Posts: 51 Location: New Zealand (Christchurch) |
Sat, 20 Apr 2013 19:05:02 +0000
Beautiful. I also wanted to install some as fell in love with them. (A) How has it affected braking, (B) how has it affected gearing around town and gearing on highway/motorway (C) what tyre size did you end up using on front and back. Cheers.
![]() 946
Posts: 6165 Location: Acworth, GA |
The Beer Guy
![]() 2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
Posts: 4744 Location: Nelson County, VA |
Sat, 20 Apr 2013 19:26:19 +0000
Masala wrote: Looks fantastic! What seat is that? |
![]() Sat, 20 Apr 2013 19:28:37 +0000
2010 GTS 300 SUPER
![]() Sat, 20 Apr 2013 19:31:07 +0000
2010 GTS 300 SUPER
VESBA wrote: Beautiful. I also wanted to install some as fell in love with them. (A) How has it affected braking, (B) how has it affected gearing around town and gearing on highway/motorway (C) what tyre size did you end up using on front and back. Cheers. B Have not tried tried that, just installed the wheel and went for a little drive... C front : 130/60-13 rear : 140/60-13 To be continued... |
![]() Sat, 20 Apr 2013 20:27:46 +0000
![]() 2007 GTS
Progetto 300 wrote: VESBA wrote: Beautiful. I also wanted to install some as fell in love with them. (A) How has it affected braking, (B) how has it affected gearing around town and gearing on highway/motorway (C) what tyre size did you end up using on front and back. Cheers. B Have not tried tried that, just installed the wheel and went for a little drive... C front : 130/60-13 rear : 140/60-13 To be continued... |
![]() Sat, 20 Apr 2013 20:29:49 +0000
2010 GTS 300 SUPER
old as dirt wrote: Progetto 300 wrote: VESBA wrote: Beautiful. I also wanted to install some as fell in love with them. (A) How has it affected braking, (B) how has it affected gearing around town and gearing on highway/motorway (C) what tyre size did you end up using on front and back. Cheers. B Have not tried tried that, just installed the wheel and went for a little drive... C front : 130/60-13 rear : 140/60-13 To be continued... |
![]() MP3 500 - GTV250
Posts: 2970 Location: Near Pittsburgh |
Sat, 20 Apr 2013 21:17:10 +0000
Scutrbrau wrote: Masala wrote: Looks fantastic! What seat is that? |
Sun, 21 Apr 2013 16:22:33 +0000
Two things:
1. That looks fantastic, the whole scoot looks fantastic! 2. Bigger wheels do not necessarily provide better "performance". I am very curious about the weight comparison to the stock set-up. Progetto 300 wrote: Finally got my 13 inchers shod with Conti Twist Sports & 15 mm white reflective striping. |
![]() 2009 GTS 250ie "Jigokuchou" 2001 ET2 "Luna"
Posts: 1572 Location: Minneapolis MN |
Sun, 21 Apr 2013 16:37:33 +0000
I'd like to know if the larger wheels have provided more stability at speed. I'm not much of a modder, but if there was significant improvement, i'd do this in a heartbeat.
The Host with the Toast
Posts: 7199 Location: SoCal |
Sun, 21 Apr 2013 16:53:47 +0000
I like the look of that bike with the 13" but the Yourban wheels here in US are like bigfoot can't find any
![]() Sun, 21 Apr 2013 19:10:47 +0000
2010 GTS 300 SUPER
![]() Sun, 21 Apr 2013 19:12:52 +0000
2010 GTS 300 SUPER
YaYaDave wrote: Scutrbrau wrote: Masala wrote: Looks fantastic! What seat is that? |
![]() Sun, 21 Apr 2013 19:14:29 +0000
2010 GTS 300 SUPER
ravenlore wrote: I'd like to know if the larger wheels have provided more stability at speed. I'm not much of a modder, but if there was significant improvement, i'd do this in a heartbeat. The wheels are larger but the tires are smaller. They just look bigger. |
![]() Sun, 21 Apr 2013 19:16:56 +0000
2010 GTS 300 SUPER
elvispa wrote: 2. Bigger wheels do not necessarily provide better "performance". I am very curious about the weight comparison to the stock set-up. Forgot to weight them.. |
![]() GTS 250 a.b.s.
Posts: 483 Location: Noord Brabant, Netherlands |
Sun, 21 Apr 2013 19:30:07 +0000
I like the look... alot..!!!!!
Great wheels and nice touch with the white rim striping. |
![]() GTS 300 Super
Posts: 670 Location: Los Angeles, CA |
Sun, 21 Apr 2013 20:21:50 +0000
wow that does look amazingly better.
And I love everything you have done to your gts. |
![]() Sun, 21 Apr 2013 20:26:49 +0000
PGO Buddy 150 "St Tropez" imported by Genuine scooter co.
Posts: 2469 Location: Charlotte |
![]() PGO Buddy 150 "St Tropez" imported by Genuine scooter co.
175mws wrote: I like the look of that bike with the 13" but the Yourban wheels here in US are like bigfoot can't find any |
Sun, 21 Apr 2013 22:41:10 +0000
Absolutely the best looking GTS ever. Perfection would require Vintage Red.
Seriously, so very clean and so very Vespa. WOW. Well done! |
2015 Vespa Sprint 150
Posts: 84 Location: San Antonio, TX |
Mon, 22 Apr 2013 03:08:07 +0000
Progetto 300 wrote: elvispa wrote: 2. Bigger wheels do not necessarily provide better "performance". I am very curious about the weight comparison to the stock set-up. Forgot to weight them.. |
Mon, 22 Apr 2013 03:14:48 +0000
Posts: 443 |
I adore your vespa. Not only do the wheel really set it off, but the clean lines are really wonderful. No crash bars, no racks, just the basic lines of the Vespa.
Mon, 22 Apr 2013 03:35:51 +0000
$175.00 each wheel from Sip.
$75 each tire + shipping to US http://www.sip-scootershop.com/en/products/rim+front+for+piaggio+mp3_pi58618r Scooter west or SDG may be able to do better on local price. Total (without shipping costs) $546.63 416.80 EUR |
![]() Mon, 22 Apr 2013 07:04:40 +0000
2010 GTS 300 SUPER
gore-tx wrote: Was this a straight swap? Were the new wheels just bolted on? How much were the Yourban wheels? |
Mon, 22 Apr 2013 18:39:19 +0000
Good Question
That kind of stability depends, of course, on the amount of weight in the rotating wheel. I don't know what the status is for this guy's wheel, but I found that putting on a set of heavy duty winter tires (Heidenau), which weighed considerably more than the stock tire, had the effect of making the scoot more committed to its line--straight or on a curve. The transition from one line to another was far slower. A trade-off, but desirable if you want the stability at speed.
ravenlore wrote: I'd like to know if the larger wheels have provided more stability at speed. I'm not much of a modder, but if there was significant improvement, i'd do this in a heartbeat. |
Sat, 27 Apr 2013 01:25:04 +0000
Thanks for all the info.
I wish the OP would post an update... |
