@richardsan avatar
looking again
@richardsan avatar
looking again
my GT dash lights don't glow/come on intermittently when turning the key to start up...jiggling the key quite a bit, while holding the brake and starter button to finesse it to engage. i was almost stranded by not being able to start 'er up.
needs replacing or pulling it out and cleaning?
tia!
The switches can go bad, and aren't that expensive. Easy to swap out, too. So I'd be replacing it as a first step.
@richardsan avatar
looking again
@richardsan avatar
looking again
cool
so there's no fiddly thing to test first...?
i'll order one up...scooter west has them for about $30.
about 11 quid if i order from 'over there'...
Your symptoms exactly describe a failing switch - so although it *could* be something else, it'd be the first thing I'd swap out.
@zagato avatar
Vespa GTV 250ie
@zagato avatar
Vespa GTV 250ie
I agree to go with the switch first. When you take the switch out, it may be an obvious problem with the switch case coming apart causing the intermittent contact.
@richardsan avatar
looking again
@richardsan avatar
looking again
thanks guys!
ordering one, just now.
[ Time: 0.0115s ][ Queries: 3 (0.0037s) ][ live ][ 313 ][ ThingOne ]
