@rod_r avatar
1990's 50s + DR 85
@rod_r avatar
1990's 50s + DR 85
As I said in another thread, my left indicator bulb keeps blowing. So, being a good google-ist, I have read up on it, and now have a couple of questions.
1. I came across a good wiring diagram.If the left is blowing, does that generally mean a possible bad earth between left bulb mounting and flasher unit only, or could it be anywhere, like:
strator to flasher unit
flasher to switch
switch to left bulb
switch to right bulb
2. The bulbs that were in the scoot, and therefore the new bulbs i bought, were all 6v / 10w, but the diagram calls up the system as 6v / 16w. Are the 10w bulbs causing the problem?
@rod_r avatar
1990's 50s + DR 85
@rod_r avatar
1990's 50s + DR 85
Problem Solved
rolled back grip and took off bar end indicator. the indicator slides into the inner cylinder divided into 4 "tabs"
the outer ring which rotates with the grip has 3 indents to bridge the gap and maintain contact when its rotating.
both inner and outer were a bit deformed and the tabs weren't sticking in far enough to make contniuous contact.
i pushed the indents in a bit and aligned the inner tabs into a neat circle so contact is always maintained.
also got 6v/15w instead of 6v/10w bulbs.
so far, so good.
[ Time: 0.0103s ][ Queries: 4 (0.0038s) ][ live ][ 313 ][ ThingOne ]
