62 vespa cushman
62 vespa cushman
any body,i bought a 1962 vespa cushman it sat since 1994 under tarp in side yard under deck,,i pulled flywheel off to look at stator,i replaced points and gapped it,put in new condensor i get spark all the way to the tip of coil wire where it meets spark plug but i see no spark at plug when i ground it to motor fin.i grabbed the coil wire while kicking it over and got a huge jolt,but still no spark coming out of plug end
any help please thanks
@ginch avatar
@ginch avatar
Has to be the plug then.
@travisnj avatar
Primasarah
1979 P200E, 1977 Rally 200, 1974 Primavera
Primasarah
@travisnj avatar
Like Ginch said, new plug or new spark plug cap / clip.
62 vespa cushman
62 vespa cushman
thanks,i tried a new plug off of my 67 coronet no luck hmmmmmm
ill try new cap maybe
thanks ginch,travis
@fabio_dougie avatar
Scooter Pimp
Scooter Pimp
Spark plug cap !!!
Fabio
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
let me see if i have this straight....you took a sparkplug out of your car and tried on your Vespa?
if this is true, you need to step away from the bike and take it to an actual mechanic.
62 vespa cushman
62 vespa cushman
no dude i didnt put my cars spark plug into my bike i just hooked it to the end of the coil and then i put the plug on the engine fin to see if a new plug would spark hopefully its the cap.
@ginch avatar
@ginch avatar
He's tried a known working spark plug and isolated the cap as the non-working part. What's wrong with that?
@jamesjohn avatar
@jamesjohn avatar
nothing. but screwing it into the head would be. dude.
62 vespa cushman
62 vespa cushman
well i put a new cap on the end and put the plug in and held it to the motor fins and no luck,no spark(really weird) i guess my ignition coil isnt producing enough juice hmmmmmmmmmm
cosa, rally, T5, italjet F125, Lambretta, plus junk
you got a jolt off the HT lead...
have you tried holding the plug when you kick it over...
spark may be faint but there....maybe
@cazshie avatar
2003 PX200
@cazshie avatar
2003 PX200
Re: no spark at plug
Could it be the HT lead/wire that's the problem?
If the insulation has broken down on the lead, and it's close to an earth, it could be draining the power away from the plug .. mibbies?
62 vespa cushman
62 vespa cushman
i did hold the plug. i definately felt spark, obviously not enough, if its not coming out of the plug end
the coil wire from the coil itself looks clean no bare wire showing that would ground
maybe the coil isnt putting out enough juice any suggestions on locating an internal coil for a 1962 125 vnb2t or for that matter a whole stator.
the shop i called said $95 smackers an hour to rebuild prob 2 hour job plus parts
@jamesjohn avatar
@jamesjohn avatar
just a note to anyone reading this post...do not shock your self holding the spark plug while kicking over the engine. It can easily kill you.
i cant believe you would knowingly do that to yourself. dumb.
62 vespa cushman
62 vespa cushman
if u dont have anything nice to say or cant help me,please dont reply
jamesjohn u obviosly have something going on because you are a very negative person and it seems this is a way for you to vent your frustrations
please dont reply to my questions anymore thank u
Please provide evidence of death by vehicle ignition system electrocution. If that was true, I would have few male friends, I would be dead, and a large part of my generation would have died long ago.
@jamesjohn avatar
@jamesjohn avatar
wow. ok then. so its a good way to test for spark? i will not try to help you again.
you can go shock yourselves silly 'cause its fun and all the kids are doing it?
the internet is very serious. lighten up guys.
@barking_mad avatar
1959 VBA, 1963 VBB2
@barking_mad avatar
1959 VBA, 1963 VBB2
JJ I do not recall in the thread anybody saying that the best way to check for spark was to shock yourself. In some cases your concern is justified especially if you have a heart condition.
I have been in the industry for a good number of years and suffered my share of unintentional shocking occasions.
lets not forget what we are all about, the love of Vespa and the idiots associated with such.
Cheers
62 vespa cushman
62 vespa cushman
good point barking mad
sorry that was me who suggested holding the plug
glad I didn't go with my first thought...which was putting it in your mouth when you kicked it over ...
Shockingly, this thread brought back a childhood ditty.
When I was young and had no sense,
I took a whiz on a 'lectric fence.
Hurt so bad down in my balls
Crapped all in my overalls.
[ Time: 0.0150s ][ Queries: 3 (0.0060s) ][ live ][ 313 ][ ThingOne ]
