Hi All,
thanks for all the help and advise so far.
I have replaced the front caliper and disk, and pads and master cylinder on my ET4.
the front brake lever is now a little floppy. when pulled it will brake fine but does not spring all the way back and so does not release the switch and the brake light stays on.
what do i need to do to get the level stiff again?
i could not find any sort of adjustments, and viagra did not seem to help
Re: More front brake problems
simonhaffenden wrote:
Hi All,
did you bleed the system ?
Yes,
I attached a clear hose to the outlet nipple , released and pumped the lever until the new fluid was showing in the container.
i then tightened the nipple and screwed on the lid.
did i miss a step?
@vespergeezer avatar
GTS300, Cosa LX200
GTS300, Cosa LX200
Yes,
did i miss a step?
Could be worth re-visiting the bleeding, being sure to use a one-way valve in the end of the rubber tube, to be sure air flow is only one-way.
Some suggest holding the lever back with strong rubber bands for a few hours to pressure the system to encourage small bubbles of air to join into larger ones that can be more easily removed after.
Geeza
@silver_streak avatar
Yes,
did i miss a step?
If you released the brake lever before you tightened the bleed screw after the last pump, then you probably drew air back into the system. As has already been suggested, you need to hold the lever down while you tighten the bleed screw, either with the help of an assistant or with a clamp or rubber band.
If you do this, a one-way valve isn't really necessary.
Thanks for the replys.
I have again bled the system with no improvement.
After head scratching and looking at the piston i realised that it did not protrude as far as the one on the old part i removed.
Also i have been unable to remove the piston from the cylinder.
Are there 2 types of master cylinder for the ETs?
All the parts lists i could find only show 1.
Is it likely that there is something holding it back?
You'll have to build up the bit of the lever that pushes against the piston. 'Liquid Steel' or Q-Bond could help here.
[ Time: 0.0151s ][ Queries: 3 (0.0066s) ][ live ][ 313 ][ ThingOne ]
