Corbin Black Leather Saddle with Back Rest for VESPA GTS - $380
Dual Saddle for Vespa GTS 250 ie & GTS 300
Lightly Used, In excellent condition.
Click HERE for my KIJIJI.CA ad.
http://www.corbin.com/vespa/vtgs2506.shtml
This Corbin seat and backrest cost over $600 new (incl. shipping cost).
Seating that is carefully designed to conform to the shape of your body and built up with Comfort Cell foam that gives long term support.
Removable backrest and you've got an excellent bike for two!
Backrest installs easily into hardware concealed inside the saddle to keep a very clean look.
Fibertech base plate material.
Basepan provides a firm foundation to support the foam shape and rides on rubber bumpers to protect your paint job.
Ergonomically shaped seating platforms that give more square inches of body contact for proper weight distribution.
Comfort Cell foam material gives a firm supportive ride that will break in over time to provide a personalized fit to your posterior.
Leather seating will breathe with your body and adapt with the foam shape during break in to support the personalized fit.
Base Pan Installs easily with latch pin and hinge included. (Replace the OEM unit with the Corbin model with removal of just two screws).
Saddle comes with weather stripping preinstalled on the seat base to secure your storage area.
The seat will hinge and latch just like the stock seat. (Corbin latch bracket is adjustable to assure perfect alignment with the seat lock).
Located in: Toronto, ON CANADA
