@david_masse avatar
@david_masse avatar
I finally completed my 2012 winter project: installing Hot Grips brand heated grips and a Warm & Safe Heat Troller electronic controller.
The project report is on my blog: http://scootcommute.blogspot.com/2012/03/project-report-installing-hot-grips.html
It was tricky to do on many levels.
First off, I couldn't find any reference on the web to anyone else having installed heated grips on a Vespa LX150. The first order of business was to do a fair bit of research to determine if the electrical system could handle the load.
Jimc at one point posted on an MV thread that he thought that the system could handle it "just"". My research allowed me to come to the same conclusion. The results of my research and the detailed conclusion are also on my blog.
The other challenges were deciding which brand of grips to purchase, removing the stock grips, and recovering from a stupid mistake when I managed to destroy the control unit.
In the end, the project was a huge success. I now have heated grips all set for when my 2012 Vespa commuting season begins in a few weeks.
My final thoughts on this project are to once more express my thanks to Jim Hollander at Hot Grips, Pat Denayer at Lockitt Group Inc., and Mike Ebers and Deata McCubbin at Warm & Safe Heated Gear for unbelievably stellar customer service, and great products.
Thanks for all your help.
great job. you should put this in the wiki. Excellent choice of grips also. Hot Grips are top of the line. You'll also like them on wet days.
@david_masse avatar
@david_masse avatar
Thanks. I have no clue how to do that, but I'll gladly give it a shot.
I think there is a post you can read and should explain it. I haven't done it either. but your grip install with all your pics and details is top notch.
@david_masse avatar
@david_masse avatar
Thanks again. I read the explanation, and I now what I need to do. It's going to take a while to transpose the html on my blog into BBcode and downsize and upload all the photos, unless I link to them... I'll figure it out
[ Time: 0.0133s ][ Queries: 3 (0.0042s) ][ live ][ 313 ][ ThingOne ]
