2007 BV500
2007 BV500
My BV500 will not start. I have charged the battery and when I try to turn it over the clock blanks out, resets to 12:00 and NOTHING ELSE. Any thoughts?
Re: 2007 BV500 wont start display goes blank
hook the battery cable s correct?
did you charge the NEW battery before installing?
2007 BV500
2007 BV500
it is a two year old batter that i charged in the scooter. I have not checked the battery terminals as of yet.... this just occurred today.
It sounds very similar to the symptoms on my Fuoco (same engine) when the sprag clutch gave out. However if you're lucky it's just a failed cell in the battery.
@aviator47 avatar
@aviator47 avatar
Welcome to MV.
Could be poor connections at the terminals, could be one or more bad cells in the battery and could be something else.
Not trying to be snarky, but connecting a charger to a bad battery will not result in a fully charged battery capable of starting the scooter. The battery will simply be charged to its lower maximum capacity. All external indications will show that the battery is "charging", but not the capacity that is available. Consequently, saying you "charged the battery" only provides limited troubleshooting help. You would need to load check the battery to know anything definitive, or at least the voltage before and during an attempt to start the engine.
Does the panel remain blank as long as the starter button is pressed, and then return to display when the starter button is released? If yes, then that does hint strongly at a dead battery. The panel draws very little current, and the display will appear at significantly lower voltage than that necessary to energize the starter motor.
Do you have a volt meter and are you familiar with how to use it?
@dru avatar
Piaggio BV500, Genuine Stella, P200e
@dru avatar
I would be willing to bet it's a battery. The wet cell batteries in these beasts is, IMO, crap. I get about a year per battery, fortunately, it's just a $44 battery. The problem isn't that the battery isn't charged, it's that even *fully* charged, it lacks the amperage to push the starter, and resets the electrical system while it gives everything it's got.
Take it to your local Battries+ and have them test it, you are probably only getting about 30-40 amps. Replace it if that's the case model#: XT10L-A2 at Batteries+, charge the new one 24hours before installing and you should be good to go for a year or so.
Mine being a daily driver, year round sees a lot of 7-8 hour periods sitting out in the weather (rain, cold, heat, etc) so I suspect that a battery that doesn't get abused like that will last longer than the year I typically get.
get a motobatt and you per year battery will go up dramatically.
@dru avatar
@dru avatar
Not that I've found, I've also had a Yuasa, and it also only lasted a little over a year. Unfortunately, as far as I can tell, the MotoBatt product doesn't offer anything toe replace the 10L's that came in the 04-07 BV500's. They went to the 12's in the 07 dual sparks and newer, which motobatt does have a replacement for .
@dru avatar
@dru avatar
I should also add that I did lose a voltage regulator during the last year, and it is apparently not unusually for a bad VR to also damage a battery, so the fact that I got another 5-6 months out of that battery was just fine with me.
You can use the bigger capacity battery.
@dru avatar
@dru avatar
It doesn't physically fit, I tried it . the 12's are about a 10mm too long and 4mm too wide. The X9 supports the 12 perfectly, but the older BV's don't. I have looked at modifying the battery pan, but that's not trivial as it requires rerouting the entire wiring harness for the tail lighting assembly .
The 10L-A2 is 135mm long, 91mm wide, and 147mm tall.
http://www.motobattbatteries.com/motobatt-mb10u.html is very close to fitting, but when I tried it, the top rubs the cover of the battery plate.
⚠️ Last edited by dru_ on UTC; edited 1 time
more cca's and better longevity as well.
Get a Ballistic battery then:
http://www.amazon.com/s/ref=nb_sb_ss_i_2_17?url=search-alias%3Daps&field-keywords=ballistic+battery+8+cell&sprefix=ballistic+battery%2Caps%2C254
Pricey, but should outlast the life of the bike, and needs no battery tender.
Edit, did you try the larger capacity motobatt battery? I understood they had smaller dimensions.
or a shorai
2007 BV500
2007 BV500
Just to update....
I replaced the battery with a shorai and it started right up...
Thank you all for your input to my little problem
[ Time: 0.0172s ][ Queries: 3 (0.0044s) ][ live ][ 313 ][ ThingOne ]
