Vespa GT200
Vespa GT200
Restoring a 68 Super for a friend and parts of the body are shot, bits welded in etc.
What body parts are available? Can you get the legshield for example?
Cheers
@killo avatar
I have a few scooters....
@killo avatar
Floor panels are available as well as front mudguard and side cowls. Beyond that, you might be better off sourcing another frame.
@ginch avatar
@ginch avatar
I just bought a floor/legshield and a horncast from Scooter-Center. It was $260 AUD delivered, which is pretty damn good I reckon. You can get cowls and front guards new too of course.
I'm hoping to put it together in the next few weeks.
I was pretty inspired by Hans from Holland, read it here '67 V50 resto
@killo avatar
@killo avatar
It's good to know that those parts are available.
@jsharpphoto avatar
1974 Vespa Sprint Veloce, 1963 VBB 180 Custom
@jsharpphoto avatar
you can build a complete small frame from parts, all from SIP. Things are out there, that aren't on the radar of the US shops. That being said, you have to be pretty good with a welder to replace that stuff yourself.
Vespa GT200
Vespa GT200
Fantastic!!! Thanks for the heads up, this will make it much easier indeed and i wont be doing the welding thank God!!
@ginch avatar
@ginch avatar
I have a good friend who offered to do some TIG welding for me, but when he looked at the stuff suggested I simply get it spot-welded as original. Don't know why that hadn't occured to me...
I'd need to put it together with a few pop rivets and take it somewhere to get that done. It shouldn't take too long so shouldn't cost much, and as he pointed out the spot weld will only do the actual weld when it has enough pressure on it. So I'm thinking it'll be possible to get an almost factory look.
That is, until I start waving the spraygun around!
@jwilliams avatar
'60 Allstate VNB1, '60 GS150 VS5, '61 Cushman VBB1, '62 GS160 Mk1 VSB1, '64 GL VLA1, '74 Rally VSE1 200 Euro, '78 P200e VSX, '06 LX150
@jwilliams avatar
I often see dismembered body bits on ebay.it (Italy)...that is, Vespa bits.
@koenig_blues avatar
ur friend is right mate, spot welded is what u need to attach those body bits, i just did that when i change my veloce floorboard and instead of using metal i use brass to do the spot welded and it sure does stronger
good luck with the project and cheer
@joshzingzing avatar
seen any sprint ausi frames going up for sale
ive got some straight leggies but can sell them yet
@markysparx avatar
Turnkey 79
Turnkey 79
@markysparx avatar
lol!
[ Time: 0.0144s ][ Queries: 5 (0.0048s) ][ live ][ 313 ][ ThingOne ]
