LX50 2T, PK80/135
LX50 2T, PK80/135
Hi all,
Firstly hello to everyone! I actually own a Vespa PK (135 conversion) rather than a modern bike but as of tomorrow morning I will also have an ET4 50.
So, whilst I'm perfectly happy working on my old bike I have no idea when it comes to the modern kind. Will be riding it home from collection tomorrow so any pointers as far as general maintenance and operation would be most appreciated. Are there any things I should check over once I have it in the same way you'd check oil and water on a car for example? And are there other little things to watch out for e.g. have seen some people talking about not filling the petrol tank to the top.
Thanks, and thanks in advance for any tips.
Matt
@ericalm avatar
Wiki Moderator
Wiki Moderator
@ericalm avatar
First thing, if it's a 50, it's an ET2. ET4s are 125s or 150s.
What year is it and how many miles on it?
If you don't know the maintenance history, then an oil (engine and gear) changes and a new oil filter are good idea.
If it has over 9,500Km or so, I'd also check the transmission: belt, rollers and clutch. The clutch can often use a good cleaning and blowout; dust and debris in there from belt wear will hamper performance.
There were ET4 50's in the RotW. I've helped a friend work on one.
LX50 2T, PK80/135
LX50 2T, PK80/135
Hi,
Thanks for the replies, very helpful.
And yes, there was indeed an ET4 50cc version.
Check the oil level occasionally. I don't know what version of the ET4 50 you have, but I bet you have an oil sight-glass rather than a dip-stick. If you can see oil half-way up the sight-glass when the cold bike is on the centre-stand on level ground - all is good. In ideal circumstances the oil level won't change much. Riding at WOT (wide open throttle) will increase oil consumption though.
I rather thought the ET4 50's were air-cooled - if so (I could be wrong) then no water to check.
Belts need to be inspected on these every few thousand miles. Rootle around the Wiki for clues as to how to get the belt out to examine and possibly change. I don't think there's anything in there directly addressing the ET4 50, but there should be enough clues. Specifically, once you've the belt in your hands, turn it inside out and look for cracking starting between the 'teeth'. Any sign of that - change the belt. Busting a belt can write-off the engine.
Apart from that, there's the usual glance at brake pads etc, but it's otherwise ride for 3-4,000 miles and then give it an oil change and check of transmission bits (belt and rollers).
@ericalm avatar
Wiki Moderator
Wiki Moderator
@ericalm avatar
The what where?
We need to change the Wiki!
Rest of the World.
LX50 2T, PK80/135
LX50 2T, PK80/135
Thanks for the replies everyone, all appreciated.
One question - yes, I do have a sightglass underneath where the oilfill is. Is it normal with this to have no dipstick? What I have is like the usual dipstick but without the stick if that makes sense. It's not broken off, just looks like it never had it.
Anyway, will get on the floor and check the sightglass tomorrow but from a quick look (whilst still standing up) the glass looks black and like I'm not going to see anything. Does this happen sometimes, is it normal? And if so how do I check the oil level?
Thanks!
[ Time: 0.0127s ][ Queries: 3 (0.0053s) ][ live ][ 313 ][ ThingOne ]
