@jackr avatar
GT200L Alabaster 2004 "Lady"
Location: Ishioka, Ibaragi Pref., Japan and Khun Han, Isaan, Thailand
@jackr avatar
There was a strange noise and I could feel strange vibration in the early acceleration timing.
Start-up, idle and initial acceleration is fine as well as the later acceleration and cruising goes.
The noise is like something is loose in the variator area with some vibration felt through the legshield.
I think it might be the belt or the rollers, but am a novice as far as mechanic is concerned. The belt was new at 6.000km (but it is a Pollini one), the rollers were new at 9.000km
She is nearly at 15.000km so due for a service and I just brought her in to her new dealer shop 35km away from my new home in the country.
I have asked them to replace the belt with a Piaggio one, replace the rollers with Malossi ones, change oil and filter and the hub oil. They should also check the spark plug, battery and brake pads.
I also asked them to have a thorough look around and to let me know if it needs anything else done.
On the way back we had a quick lunch of sausages, soup and rice finished with one scoop of ice cream all for the equivalent of 14 US$
Oh and I got a 125cc SYM to replace the Vespa during her stay at the shop
@wleuthold avatar
2006 Vespa GT (Rocket): 2005 Vespa GT (Razzo): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125: 2018 Yamaha Xmax (Big Ugly), 2023 Vespa GTS300 (Ghost)
@wleuthold avatar
Nothing like living the good life, Jack. It looks like you have settled into the retired life comfortably. Good for you.
As for the noise, it could be the belt falling apart. My one attempt at using a non Piaggio belt ended with it being replaced right after it began to fall apart. Luckily it held together just long enough to not leave me stranded anywhere. I have had very good results with Piaggio belts. The last one lasted almost 12,000 miles and still looked good when replaced.
Cool. How do you like the new shop you have near you? Ain't retired life great.? 8)
@jackr avatar
@jackr avatar
Hi Judy,
Yes retired life is great, still looking like a warehouse with unpacked boxes but it is slowly getting into shape.
Trying to cook for myself is one of my biggest challenges for the moment Crying or Very sad emoticon
As far as the shop is concerned it seems to have known better days but they have the know-how for Vespas and are their nearest dealer (35km away)
Will know more as they come up with the diagnostic and service details
I am off to the pool for my morning swim !
Safe riding
@jackr avatar
@jackr avatar
Just spoke the mechano at the shop over the phone and he said the bearings were the cause of the strange noise I was experiencing
I do not have any more info for the moment but am quite worried that there is some damage done although I don't know what or where those bearings are.
It sounded coming from the variator area......
Any guesses at what it might be ?
@jackr avatar
@jackr avatar
Here we go the clutch bearings need replacing !
At 15.000km it is a little early I would have thought but I suppose that put them under strain by using the red springs for the Malossi clutch.
Just me thinking aloud .....
@wleuthold avatar
@wleuthold avatar
That is too bad! I have four times your mileage and no real problems ever. My only real issue has been the exhaust gasket that has blown out four times, finally solved with a Leo Vince.
During the last belt change I installed Dr. Pulley Sliders and thoroughly cleaned the clutch bell housing with a Scotch Brite pad. It has been over 3000 miles and I still have no squealing clutch while accelerating from a stop.
@jackr avatar
@jackr avatar
Well I went to pick her up yesterday at the new shop.
They had all the parts they changed in a plastic tray to show me
Belt, nuts, clutch bearing, brake pads, etc.
She runs great and feels like new, top speed is increased a bit probably because of the new belt. The old one was fine but used on the sides Good for a Pollini belt, more than 10.000km
The bill came to the equivalent of 500 US$ mostly because of the time it took for the work to be done
Spring here I come ! Ready for the warmer days ahead
Safe riding to all
[ Time: 0.0164s ][ Queries: 4 (0.0083s) ][ live ][ 313 ][ ThingOne ]
