@rbertoni avatar
MP3 500
@rbertoni avatar
MP3 500
I just completed my first belt change on my MP3 500 and installed Dr. Pulley sliders. I had a lot of help from many on this forum that have provided instructions and guidence. I just want to thank everyone that posted on this topic.
I do have a couple of questions concerning my experience. I installed the "new" belt and 25x 17 Dr. Pulley's.
When I finished, the trike would not start at first. I had to grind it several times for 10 seconds or more each time until it finally started. Now it starts right up. Is that normal? Anyone know what causes it?
Also, I noticed that I'm idling at a higher RPM than before. I always idled at 10k rpm and now I'm sitting at about 15k rpm. Again, is this normal?
I noticed the acceleration is SMOOTH with the sliders and the trike is much more responsive when accelerating.
your idle was 1000 rpm and now its 1500 rpm not 10k which is 10,000.
Normal idle should be where your at if its cold, when fully warm maybe a little lower.
not sure why it didn't start right off. How old is the battery?
the Dr pulleys are performing like they are suppose to.
Correct idle speed for the 500 is ~1500rpm anyway.
@rbertoni avatar
MP3 500
@rbertoni avatar
MP3 500
I was idling lower, so I'm glad to here that I'm now idling correctly. The battery is a year old but cranked it with no issues. After it finially started, it corrected itseft and now fires right up. The vibrations from the low idle was pretty bad, but the new belt and rollers and higher idle RPM has helped that situation a lot.
It did have me worried there for a while when it wouldn't start.
@rbertoni avatar
MP3 500
@rbertoni avatar
MP3 500
Thanks for the correction, I knew that but certainly didn't write that.
[ Time: 0.0115s ][ Queries: 3 (0.0040s) ][ live ][ 313 ][ ThingOne ]
