Vespa T5 - GTS250 - HEAT
Toying with the idea of upgrading the carb on my T5. It is a Malossi 172, 21 tooth clutch breathing through a Taffspeed exhaust.
Its running standard auto-lube carb at the moment. I dont want to go to a really large Dellorto 28mm car etc. Hear good things about Hotrod Scooters Vortex carb. Anyone any thoughts and a link to the guy who makes them?
@jackson85 avatar
@jackson85 avatar
guys on here swear by the al fella. as far as I know though, the vortex card does 3% mix at all revs. open to correction of course
@gickspeed avatar
@gickspeed avatar
Vortex carb has nothing to do with mixture.
Mixture is decided on the oil injection system mounted in the carb box or the the amount of oil added to the gas if premixing.
For Vespa rotary valve engines, premix at 2% and jet your engine correctly.
Running anything more is not sound and you may be leaning your jetting by adding extra oil.
Off topic, but I see it often on this board.
cosa, rally, T5, italjet F125, Lambretta, plus junk
what does " not sound" mean??
and if you jet your bike using 3% theres no problem, is there ?
@gickspeed avatar
@gickspeed avatar
You can use 10%, I don't really care. Beyond 2%, it's money down the drain.
Just know this, think of jetting independent of your mixture rate.
I know I don't carry much weight on this fair forum, but I professionally port racing topends. They are often radical and at times, beyond what most people run. I use 2% mixture. My customers use 2% mixture. Adjust your rich/lean jetting by changing your main jet. Even when things can get radical, jetting is always the same process via changing the main jet.
why would kit manufacturers recommend 3%?
@gickspeed avatar
@gickspeed avatar
Why would manufactures sell topends with 3.5mm of squish? Malossi not even being close.
While it doesn't hurt you per se, it doesn't help. If I was a betting man, some of that may be suggesting covering the magnitude is sin that some tuners/riders will create.
Like I said before, think of jetting independent of mixture rate.
@hojo1690 avatar
1980 P200e, 1956 ACMA, 1979 P200e, 1974 Ciao
@hojo1690 avatar
I got a Vortex carb just recently from Al at HotRod. (http://http://hotrodscooters.com/). It definitely draws a ton more air than my stock 24/24si. The stock carb could not pull enough air to feed my 226 Vintage Hot Wing. When I got about about 6000 RPM, it would bog out. With the Vortex, I'm having no such problems. The powerband is between 6,000-8,000 RPM, and I've run it to 10,000 without sensing airflow issues.
As pointed out above, the oil injection is part of the lower airbox, which the Vortex does not replace. Al provides a carburetor and airbox lid, while using the airbox you already have.
Hojo
nothing at all
nothing at all
Just to add to Gick and Hojo...........Your t5 should have come with a 24g which has a larger air filter than the 24e.
I don't know, check and see what 24 you have, you never mentioned it in your op.
T5 carb
Its a standard T5 Dellorto 24G using a 25 main jet. Oh and by the way, the http://http://hotrodscooters.com link wont work
@rgconner avatar
GTS250
@rgconner avatar
GTS250
Re: T5 carb
I should have my P200 engine back and it will have a vortex with the expanded airbox.
Starting jet size is going to be 179ish. That means it is drawing double the air and double the fuel over the 118 stock.
(Hole size is 50% bigger diameter, so about double the flow)
[ Time: 0.0144s ][ Queries: 3 (0.0054s) ][ live ][ 313 ][ ThingOne ]
