@napacoach avatar
M@
@napacoach avatar
M@
just need to know what size to order
@theoz avatar
Sir Frets-A-Lot
Sir Frets-A-Lot
@theoz avatar
See, I'd do that but I worry about losing my ability to split lanes
Already my mirrors nearly take out side views all the time. Oberons = scraping the doors of every SUV in SF
Napa look at you trickin out your new scoot Have fun
@napacoach avatar
M@
@napacoach avatar
M@
sweet revenge
@mesmer avatar
GT200
@mesmer avatar
GT200
I wonder if the Oberons would give you a better sense of your "actual size". When I split I'm alway imagining my mirrors smacking the mirror of an SUV or full size truck. But with the Oberons you could rest your hands towards the outside of the grips and then all you'd need to remember if that if your hands/grips can slip through, mentally add 3-4 inches and the rest of you should fit through as well.
Just a thought. I'll have to try M@'s out and see how they work
@theoz avatar
Sir Frets-A-Lot
Sir Frets-A-Lot
@theoz avatar
for me, mirrors smacking cars has everything to do with the height of the car. I know how big I am but how meaningful that size is depends on the height of those obstructions - like SUVs all have really tall mirrors. So really it's a matter of realizing how "tall" I am
⬆️    About 4 years elapsed    ⬇️
@panos avatar
@panos avatar
does anyone knows what s the weight of the oberon bar end mirrors?the stock bar ends are about 270gr. each.if the oberon are lighter is gonna be a problem so if you know answer.thanks. 8)
dont know the weight but with thwe jettin bar end weights and oberon mirrors the front wabble was so bad i went back to stock thus wasting about £50
The Host with the Toast
All Alloy Jettin alloy Barends weigh 4oz.
4 ounces = 113.398093 grams
The Steel "Barbell" Barends weigh 15oz.
15 ounces = 425.242847 grams
Front end wobble seems to be fixed with proper inflation
No. In your case, maybe. But there are many, many causes of wobble. If proper inflation fixed it for everyone, there wouldn't be nearly as much bitching about it.
true, mine went away with a 130 Avon tire and over inflation of 2 psi. not 100% but much better than what I had. I also removed topcase/ top box
and I have Jettin 15oz Bar ends not for wobble I changed my mirrors to lane splitters.
2006 LX150 and 2006 GTS
I have been wanting to shorten my OEM mirrors so that I don't get so close when lane splitting is necessary. It seems like having the mirrors at the bars ends would make looking at the mirrors more difficult when you need to.
@panos avatar
@panos avatar
i like these http://www.oberon-performance.co.uk/acatalog/60mm_Bar_End_Mirrors.html but i think that they are too light for what we need.i remember that a guy here had them but i don t remember what whas his impression about the wobble.does anyone else knows?
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
for a second I thought M@ was back.... What The? emoticon
(learning to hate necro posts...)
@progetto_300 avatar
2010 GTS 300 SUPER
2010 GTS 300 SUPER
I just fitted those to my GTS (i had them on my LX)
First of all, you have to cut the small piece at the "inner" side because it won't fit in the handlebars.
When that's done, there is still an ugly spacing between the grip and bar-ends of about 5 mm (+- 0,2 inch).
The original bar-end are cut out so the handlebar fits in the bar-end.
With the Oberons it's the opposite.
Also they are made from alu and a lot lighter than the original bar-ends.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
Tricked by necro posters again!
[ Time: 0.0155s ][ Queries: 3 (0.0046s) ][ live ][ 343 ][ ThingOne ]
