Wonder Machine wrote:
When I did my CBT, the instructor also told me that covering the brakes was the wrong thing to do.
He said that riding a scooter is not like riding a bicycle - you do not use the brakes in the same way. Covering the front brake and using the throttle at the same time can contribute to the front wheel locking, while the back end swings out and you are on the floor. This is so easy to do that I suggest to anyone who wants to lay out a bike, I would open the throttle start a figure of eight and then grab the front brake on the first turn.
If you don't have appropriate speed as well as braking, covering the brakes can lead to you losing control, not gaining it. This is particularly true if you are taking a corner, or avoiding an obstacle. Brake covering is a no no because in an emergency you often don't make a conscious decision to brake, you just grab the brakes. If you don't cover them, then you should take account of what's going on around you, reduce speed and then brake as necesary.
Speed is an essential factor in control of your machine, so you should use the throttle to control speed, rather than using the brakes as the only method to slow down. In urban riding it is very easy to ram the throttle then squeal off into the distance and then slap the brakes on to stop. I don't think this is great riding but it seems exciting to some!
In the UK, you could try reading the excellent "Police Riders Handbook To Better Motorcycling" which is standard issue for police bikers and can be bought from Amazon. I can really recommend it. It has improved my cornering, observation, positioning understanding of the road. I've also got a lot more fun out the Vespa!
While I understand the logic of this, and can see how jamming on the brakes while throttling isn't such a great idea, I think most of us are referring to covering the brakes
only while riding in dense traffic situations (parking lots, busy intersections) at speeds of 30 mph (48 kph) or less...not while zooming down the interstate at 65 miles an hour (104 kph). I agree, using the throttle as a speed regulator is important, and in no way am I suggesting that one should apply the brakes
while throttling, but in heavy traffic situations, I still think it's a good idea to have your fingers on the lever prepared for a hard brake in case the situation arises suddenly...
To quote a specific line from above "Brake covering is a no no because in an emergency you often don't make a conscious decision to brake, you just grab the brakes."
Actually, the REAL no no in this situation isn't the "brake covering" but rather the unconscious reaction (or rather, the habit) of grabbing the brakes. If you practice proper braking techniques enough (I love ariw22's suggestions about squeezing an orange), especially proper hard braking techniques, over time you can replace bad habits with good ones (even unconscious ones). It's all about practice, people.
As for the Police Riders handbook, I'm sure it's a great read and I'll definitely have to check it out, but I think people should also be aware that according to some veterans, police are still being taught improper procedures...at least here in the states. (For instance, many are taught to lay down their bikes in certain situations where proper hard braking techniques would undoubtedly work better. Brake pads offer a lot more stopping friction than skidding metal and plastic.)
