LX150: Euro Turn Signal Kit Installation
Overview
This kit, from Motorsport Scooters, allows you to remove the front pod turn signals, converting the original Euro turn signals into running lights and turn signals. The kit plugs right in (no soldering, no cutting wires). Kit includes: wire harness, 2 bulb holders, 2 yellow dual filament bulbs, zip ties, hole plugs, and instructions.
NOTE: This kit will only fit the 150cc models. It will not fit the 50cc models.
Video Tutorial
You can also watch this video on blogger.
Tools
Required
  • Small Flat Blade Screwdriver
  • #2 Phillips Head Screwdriver
  • 3mm Hex Allen Wrench
  • 8mm Wrench or Socket
  • 17mm Open-Ended Wrench
  • Diagonal Cutting Pliers
Nice to have
  • Magnetic Tool
  • Medium-Long Length Wire Ties (The kit includes 3 small and 1 large.)
  • Shop Light
Tips
This kit is very easy to install. This would be a great first project for someone not familiar the electrical components of a modern Vespa. Installation time is approximately 1-2 hours depending on skill level.
Contributed by MV user Frank with the help of his daughter Maureen.
Last Updated Mon Apr 19, 2010 12:17 pm
[ Time: 0.1003s ][ Queries: 4 (0.0792s) ][ Debug on ][ 211 ][ Thing One ]
